i have this annoying oil leak coming from the lower right side of the timing chain cover. i have had the cover off 3 times trying to fix (new gaskets and sealant). it is not the crank seal. it seeps out right where the cover and the pan meet. it will only leak when the engine is above idle like the oil is being pushed past the gasket from the timing chain. is there anyone else who has had this problem? what else could i do to solve this?
