I've installed these hooker comps 1 7/8 in two other b-bodies without much issue. One barely tapped the torsion bar with the lumpy idle. I disconnected the exhaust and just pulled the header away from the bar by hand and it was enough to keep it from jingling... Both cars were floor shift so I wanted to make sure I didn't need to change the column shift with these...
