It's great to see that wagon made it to Iowa! Where in Iowa are you?
It's fairly similar to my 68 Coronet 440 wagon. My drivetrain is a pump gas 440/727/3.23 sure grip.
My plans involve a paint job (color to be determined) and a white 67 Charger quad bucket seat interior.
I also have a full set of the stainless side window trim and NOS rear qtr moldings.
If you look you will notice that the front and rear wheel openings don't match on 68-70 Coronet wagons. Chrysler used the same wagon body for both Dodge and Plymouth B-body wagons. The wheel lip trim on Coronets helps hide the mismatch.
I should have my wagon at the DesMoines Good Guys in July. Are you going?
Talk to you later.
Carmak
Riverside, Iowa
