Mine does not have a shaker so can't say for sure it will clear but I would think that it cold be trimmed shorter at the thermostat housing to lower it to clear. I'll get the number tonight and take a picture at the same time. NAPA should be able to cross the Dayco number. Just be aware that the hose has another bend and an additional 12-14" of length so when you initially see it, it looks totally wrong but once you cut it down, it works fine.
do you knwo what the over all length was? I cant seem to find that hose anywhere, it comes back as power steering hose.
