Have a look at the Dayco 70434 hose. I think that is the number I used for mine. It has to be trimmed to fit but it has the correct length and bends once you cut a fair portion of it off. I'll check this evening to make sure that is the right number.
Is that an interchangable number for like napa, etc? Would that hose clear under a shaker base? Thanks for the help. Let me know for sure on the number when you get a chance
