I was using a solid mount on the drivers side and a regular NAPA replacement mount on the pass. side (replaced twice in 4 months). After just a couple of use's the engine sag's so much on the pass. side the inner tie rod end's hit the header putting deep enough grooves that they need to be welded. I will be switching to Schumacher's.
