Quote: When I hooked the vac gauge up to that port, I only got about 5 psi. Vac gauge connected to the driver side port gives me 20 psi.
Don't mean to nit pick, but when you are using a vacuum gauge to measure carb port or manifold vacuum you are typically measuring in units of Inches of Mercury (In. Hg) not psi (pounds per square inch).
