It is recommended not to exceed .495 lift with stock valve train. Make sure the springs you use are compatible, comp 901 should be good. Like scratchn said, the clearance between guide and retainer is crucial, don't use the rotators. Check those 302 castings, they can be prone to cracking in the valve area.
