Maybe this is a dumb question..but what of the so-called "wide block" 318 Poly? Is it the same block as the LA? Is it the heads that make the poly look so wide?
Yes, the poly 318 block isn't any wider than a wedge 318 block.
Thanks, 413, once again you are a great source for classic Chrysler motor specifications!
As a side note, wouldn't it be great if you could get speed parts for the poly head..or better yet have an aluminum poly SR head produced that would bolt on to a later LA 4 bolt block.
