the poly 318 was from 1959 i believe till 1966.after 1967 it is what we know as the LA motor,,
the poly head uses a staggered valve set up, some parts are interchangable to the LA,, oil pan i believe and dizzy,,same timing cover i belive.
go to allpar.com you can read about it there,,,
i have always thought these motors put out more power then a LA type 318,and there seems to be a ton of intrest down under,,also i believe you would find some poly 318 guys on the H.A.M.B.
not to be confused with the early poly motors of the mid 1950s, totally different blocks,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
