Quote: Isn't it possible to convert the efi to a carb mount??? Doesn't take but a good welder to fill the injector holes or what a minute put a fuel rail on it for n.o.s???? HUM sounds like an idea
I'm going to have some aluminum plugs made that have o-rings on them & insert them into the injector bores. With a little bit if blue Loctite they should be fine. I don't want to weld up the injector bores, should I decide to go to F.I. some day.
Quote: Hey Steff
Looks good. Glad you found a intake. I was a little nervous.
Jerry
Thanx Jerry! I was getting a little nervous too & was glad to find a manifold.
