taking a page here from Duster Dave's creation
Like everything else on this car, nothing was an easy bolt on. Round filter elements would not fit inside the BDS Dominator blower scoop. I came up with a design that uses a flat style K&N filter element. To make it work, I made an aluminum filter base that fits tightly inside the scoop, and is held in place with just one screw. A pair of 3/8" aluminum C-channels and 4 screws holds the element securely in place.
that has less area than a 6pac filter.
