The instructions with my lunati cam said to run it between 2500-3000rpm for 20 minutes, varying the rpm up/down by 200 every minute or so. Then shut off, change oil and you're good to go. I followed what they said to do and had no issues. I did add in some of the old style GM EOS to pump up the zinc level during break-in.
