Of course, the problem with removing metal here is that you're guessing that the manufacturer left extra un-needed material here.
If he did an excellent job designing it (and there's no metal that isn't structurally required), it's going to break right where you cut it - it's a stress riser, and the lower edge is in tension.
Boffin Emeritus
