I had my indy 360-1 heads fully cleaned up with a full port job, milled and new springs installed at 2.00" install height. My problem now is the underside of the rockers are hitting the valve retainers and T&D tells me i'm stuck, no way to correct this unless i buy different set of their rockers.
