Re: More Useless SB Edelbrock Flow #'s........
[Re: fast68plymouth]
#7052
11/06/03 11:43 PM
11/06/03 11:43 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Here's a set that I did not port, these were done by a shop in GA. And Dwayne did the VJ and 30* back cut the valves. This is the set that is for sale on ebay right now. Owner is getting rid of them to get some INDY 360-1's for a 416, and I listed them for him after flowing them. I would consider these Stage 2 port work. The porter pushed the pushrod pinches hard enough to break through on 2 of them, and Dwayne sleeved them.
thats not exactly correct.
the place that did the head work originally must have had pretty poor/old tooling. the valves had been refaced with a valve grinder with a worn out chuck, and the faces werent even close to being concentric with the stems. this shop had also spent a fair amount of time doing some kind of re-profiling of the back side of the valve. sort of like a back cut, but then blended into the seat/back of the valve. the actual face was also very narrow. the seat work wasnt all that great either, so i touched up the valve seats, and refaced the valves.....but i dont recall doing anything additional in the way of a back cut on top of what had been done previously. the only reason i mention all this is i dont want who ever buys them to look at what was done to the back side of the valves and think that was something i did.
LOL I was actually going to send you a PM about that when I first saw the valves last week. It almost looks like they did a 30* BC and then took a damn sand roll and tried to break the hard edge and radius to the seat. It's weird looking. You can see the sand roll marks if you look VERY close. I did'nt know if you did that or what......I guess the best way to describe it, is it looks just like a Ferrea "P" series valve that has a radiused 30. I just figured you must have done it, as I never would have guessed those clowns in GA would have, as is obvious that they spent a considerable amount of time messing with the backsides of those valves.
