Ok then loosen the rubber mount to K frame bolts , jack up under the oil pan and see if you can get it relocated .
Reason I ask is because according to Megaparts there are body specific engine brackets, and I wasn't sure if you were using conversion mounts of some sort .
hey John is there a difference in C-body and B-body MM brackets????
Wedge , depends on the year , but I'll say after 68 , or 69 ??? , no.
