Thanks for the responses guys.
I thought that the N96 was the air grabber code? Is that correct?
Yes that is the Code for Air Grabber , ALL hemi cars had it .
The only way to know if it's an original tach car is to look at the Broadcast Sheet, it's not on the fender tag . the hole in your firewall on the drivers side is not in the correct location for the tach , added by a previous owner .
This is not correct, if a car came with a Tach it is on the fender tag, N85
It depends on what plant produced the car, I don't think Lynch Rd. built cars coded it.
Definitely not on ANY lynch rd. tag I have ever seen, including my tac equipped 69 Bee ...
You may be right about Lynch rd cars, but it was on the tag for St Louis cars, I dont think the poster said where his car was from
