It could be a lot of things. What checking have you done so far? Have you tried cleaning the throttle body or IAC? Whens the last time the air and fuel filters were changed?
i haven't done anything yet. the fuel filter has me a little confused. is it part of the fuel pump? some research tells me there is a canister on top of the gas tank that holds the filter. i don't want to drop the tank twice.
i will go clean the throttle body right now.
when i come to a stop i can keep it running with on foot on the brake and one giving it a little gas.
thanks for your help.
