If all elae fails pull the plugs, spin the engine to clear the cylinders and then try it.
If you are going to do this, make sure you pull the coil wire out of the coil before you start to spin the engine. You'll have gas fumes going everywhere DAMHIK!!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
