Looking at diagrams of how the shift tabs should be, I see they would all be "up" if this was a pre-74 non-od unit. Not only do I have to flip the 3/4 lever so it is "down"...the reverse lever also needs to be in a "down" position for my shifter to work properly. I'm confused...
