Anything you guys reccomend doing/checking?
thanks!
Get a baseline on what you have now: compression test/leakdown test/idle vacuum/initial timing/slot curve/mixture. I'd advance the cam 4 deg for a start to effect some gain that you can feel keeping in mind that it'll decrease the PV clearance on either the intake or the ex valves (not sure which).
