Re: Blown motors and roller lifters.............
[Re: BobR]
#678420
04/23/10 11:58 PM
04/23/10 11:58 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I would think the bushing would be the way to go, a buddy of mine ,also big block chevy just broke a roller , needle bearings went through the pickup screen into the pump which locked up , then screwing the dizzy right off the intake. $$$$ Tear down, Replace cam, pump, gear on dizzy, heli coil intake , gaskets etc. Yeh, bushings.
Good lifters don't do that. We have never had a lifter failure of any kind and we run a lot of cam, a lot of spring pressure and 9800 RPM.
He doesn't run cheep stuff and they were not that old. I think it was one of those freek deals. Just a tad under .800 lift and 7400 rpm's
it's ok to butt heads, just don't do it with a butthead
