Re: Blown motors and roller lifters.............
[Re: BobR]
#678419
04/23/10 11:10 PM
04/23/10 11:10 PM
Posts: 705 Michigan
Hemiroid
Michigan
I would think the bushing would be the way to go, a buddy of mine ,also big block chevy just broke a roller , needle bearings went through the pickup screen into the pump which locked up , then screwing the dizzy right off the intake. $$$$ Tear down, Replace cam, pump, gear on dizzy, heli coil intake , gaskets etc. Yeh, bushings.
Good lifters don't do that. We have never had a lifter failure of any kind and we run a lot of cam, a lot of spring pressure and 9800 RPM.
Bob,
How many laps before the lifters get replaced? Not everyone can afford to change a $2500+ set of lifters every 30 laps.
