Quote: I`ve never had luck w/just the o-ring so I use the paper gasket around the base also......problem solved.
Same thing I thought, just wasn't sure as the oil pressure being 50-75# seems unusual for a stock melling pump on a stock 360 long=block rebuild..???? Will have to grab some gaskets tomorrow and try-em out...
