You would have to upgrade to the later dual feed field higher output alternator to do this. Some refer to this as double field alternator but in reality the others also have 2 fields but one is grounded internally. Really the alternator you have now should keep that battery charged if you aren't running with a bunch of electrical draw assesories.
