What vacuum are you talking about???????Dose not make sence. Did you check the things that i mentioned? You have to find the source of your problem before trying to cover it up with a spacer. Belive me the spacer is not your problem. I have thousands of cars i have worked on that do not have a spacer and they run fine. It did not come with one from the factory. It ran before so it has to run again.
JAKES AUTOMOTIVE
