yes i agree. i didn't have another gear set around when i put it together to check. so this is what happenes when you run 4 teeth off.
Holy crap, that's awful!
My marks are off like one tooth-ish. But I did check
valve position and tdc and it's where it should be
when both valves are closed so I'm going to assume
this is good enough to go. The marks are just kind of weird on this set. they look more like the letter o than a real mark......
Very sorry your engine crashed. Hopefully it's on the mend now.
