I used a pair of 8 3/4 35 spline Moser axles in my Dana with a Strange spool with no issues.
Gus
hmm I had no idea the Dana60 used the same shafts as the 8.75 with the exception of length issues.
Just to clarify, it's only between the same spline counts.
OEM 8 3/4" are normally 30 spline. OEM Dana 60 are normally 23(?) and 35 spline. Aftermarket 35 spline spools and axles are available for 8 3/4's and those axles are basically the same as 35 spline Dana 60 axles, except for length per application. (In car applications.)
