Re: How loud is your valvetrain?
[Re: 451Mopar]
#670662
04/16/10 03:03 PM
04/16/10 03:03 PM
Posts: 2,928 Canada
RobR
Canada
When I get back in town, I will have to get my wifes digital camera and do a quick video with sound to post. Monday, I did a video on my cell phone, but the sound quality is really bad, and when I tried to copy the file to my computer all i got was video, no audio?
The cam is a custom comp HXL 264/264 @ 0.050", (187@0.200"), 0.714"/0.714" lift, 112 LSA, 108 cl solid roller cam. Here is comps description of the lobe profiles:
"HXL SERIES ROLLERS The HXL Series rollers are intended for high lift applications that require maximum torque and extended rpm. These fall somewhere in between the RX and TK Series in terms of aggressiveness but provide more lobe lift. They are closest to the High Torque .440" lobes but have incorporated our latest profile advancements that should allow higher engine speeds and improved dynamics."
The heads are Max wedge port Edelbrock Victors.
187@200 shouldn't be closing the valve hard enough for you to hear it.
