mid 11 volts to the Ballast/2.8 @coil as said if the wire/connections from the ballast "out" downstream to the coil positive are good then the ballast is bad/dropping the voltage too much but I've got a feeling that isn't the case
Could you please clarify in English?
Mid 11 volts to the Ballast/2.8 at the coil.
As said, if the wire/connections from the ballast "out" downstream to the coil positive are good, then the ballast is bad/dropping the voltage too much.
I've got a feeling that isn't the case.
