While installing the MF pump I also upgraded to a -12 feed line and had a hell of a time getting the new sump fitting to stop leaking.
Then, just prior to this vid, I had a needle and seat hanging up so I was dumping fuel through the boosters. Luckily that was an easy fix with a little blast of air.
