The man, the legend..................JoeZ! That sounds like a trick setup Joe, but I just want to find a decent gasket that I can throw on there and get running w/o having any machine work done.
My Summit gaskets probably would have been fine with some Moroso ceramic seal but since the motor is out for the oil pan I figured I'd do it right.
I'll measure my o-ring height this weekend but it doesn't stick out enough to cause problems, it left a very small indentation in the copper gaskets. I'll lay a flat edge across them this weekend and slide a feeler gauge in there.
SCE says either the heads or the block need to be o-ringed, not both, but both is probably better I would think.
I was all excited about the SCE Titans with the sealer and they are .032 thick which would help my compression since the piston is .016 in the hole. I wonder if I could run a bead of better sealer alongside their sealer
![](/ubbthreads/images/graemlins/smile.gif)
, or just get the ones with no sealer. Or aneal mine.
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I'm still confused.
I'd just like to locate some MP 4529455's!!!
![](/ubbthreads/images/graemlins/smilie_help.gif)
