So is there a source for a frame connector for the 73-74 b bodys?
I see the C.E.s are shown to fit up to 74, but do they?
You can make your own with some thin wall 2 X 3 tubing. The trick is to cut the rear floor pans so the tube sits in the floor slightly (rear floor is lower than front) then re-weld the floor to the tube. You wont even notice them from the side of the car and it will stiffen the entire car considerably.
