will the straight axle set up from a 1950 dodge 1/2 ton pickup fit under a 1950 plymouth without much trouble? it looks like the dodges steering box mounts in about the same spot as the ply. i want a straight axle for my business coupe, but can't afford a speedway motors kit. any help or pics of what other guys have done. i want to use the original frame rails too.
