is the zinc needed just for break in, or do flat tappet engines continue to need zinc? From what I read, I got the idea that new oil probably still has enough zinc for lubrication once the cam is broken in?
i still use the zinc oil after break in. i might not have to, but i am not willing to risk the $300 cam.
71 scamp big block with 915 heads 727 trans
