This is absolutely a known problem with dual line kits and has nothing to do with sealing. I put a single line on my last build and that solved the problem. Single lines are adequate for most engines. You can also use check valves in the dual lines but if you do this use GOOD check valves. I got mine from Kinsler for my last dual line and they cost almost as much as the system.
