You know the same thing happen to me when I got a zit on my nose. Turns out they were not related.
I kind of doubt your one problem is related to the other unless maybe you changed something else at the same time.
Maybe a vacuum leak?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
