The 273 used the same heads for the commandos and non commandos untill the commando went away in 68 then they used the 318 open chamber head. Absolutly nothing special about a head from a commando VS a head from a 2bl motor.
As for how many cubes they can support, well that depends on how many RPM you want to turn. The 273 D-dart engines would go 7000 so in a 360 that would equal about 5300 rpm. The 360 will unshroud the valves a little more so might go 5500, max ported with big valves they can mabey make 400hp on a 360.
For casting numbers they are probably a 315 or 920 depending on year. 920 was the 67 only head.
and if they're 315 heads, they're probably the funky oddball intake bolt angle used in 64-65 or 64-66 IIRC.
port volume wise, for a performance app, I wouldn't go above a 318 for displacement. for a torque app, they'd be nice on a stock long block 360 with a small, fast rate cam (voodoo 60401 maybe)
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
