Quote: I don't claim to be an expert on neutral safety switches..in fact...I don't really now squat about them. When you turn the engine over, doesn't the neutral safety preclude the plugs from firing? If mine fire in sequence, that would indicate the ability for the motor to ignite the fuel? So, as a dummy..where does the neutral safety switch prevent the ignition system from functioning? Yeah, off topic, but still a good subject to learn from... and I am out of gas in my spare can cuz the kids put it in the four wheelers today
The neutral safety switch prevents the starter from turning over the engine. If the engine turns over the switch is engaged.
