I'm looking at a diff with a small yolk. I need a big yolk, but this is a good deal. How difficult is it to change out a yolk? Does it bolt in or require more disassembly of the diff?
What kinda chickens do you have?
A yolk is the yellow part of an egg.
A yoke is what is on a rear...No it's no big deal but if it's a crushed sleeve,some say you should replace it when changing yoke's...I got away with just changing it before. Make sure it's torqued back on so it doesn't loosen up later...
