That is only ONE screw ...and the height-spec is not "standard" .. it can vary. Do you have a pic of yours?
And is your rich-situation through all ranges of operation ?
Where is the one screw on the carb supposed to be. The small one in the center triangle? I know it is not standard. I just need to play around with it. It is rich through everything. It runs nice but is massively rich to the point of having to change my clothes after 30 seconds of running.
