Snoopy's pic is accurate for the routing...So in order to get the harness through the correct clamps you'll need to pull out the gauge cluster and possibly the ashtray to add the wiring and relay to a car that does'nt have it... And also since we're on the roadlamps...Here's an old post that shows the differences between the older repops and the original roadlamps...B/E&A has the roadlamps with the correct housings and stampings available.. .... link
