Well its pretty pleasant out tonight so I went out and ran a jumper from the green 2V side of the VR to the field of the alternator with no result. I disconnected the wire from the same side of the VR while doing the test. was that the right way to do it?
So is the field supposed to have a voltage to it? I'm assuming yes? If so, why would mine be showing continuity to ground?
Thanks!
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
