OK, I tried PB Blaster..no luck, heat..no luck, drift..no luck(it just bent the cam). I'm starting to think that I'm going to have to cut the adjuster bolt out. Not sure how yet though. I have a grinder, saws all, and dremel. I think the grinder and saws all are too big, but I don't have a cutting disc big enough for the dremel.
