Quote: What I meant was if the addition of the overdrive trans would benefit that much in city driving?
It would benefit you little to nothing. I don't think the lockup converter or the overdrive gear kick in until near or over 50mph, and even at that speed without the overdrive you're not revving high enough to need that extra gear. Below that speed you're hauling around the extra weight for nothing.
