I did this swap in my 67 Barracuda last year, as far as reliability, you can't beat that! quick starts and nice cruising. I got an A-999 lock up trans wich is stronger than the usual 904 and keeping the floor shifter and linkage, so no hammering the tunnel..
THe OBDI is very easy to use with only 5 wires to connect to the computer...
