Thanks to all, It was bad grounds, the dash mounts needed to be sanded, one rear bulb was burned out, the tail lights werent grounded because I used little nylon washers as not to scratch the paint.. live and learn I guess also one front blinker wasnt hooked up, the other had bad contacts and needed to be cleaned, the horn still doesnt shut off but oh well I can temporarily live with that thanks again nathan
