At the last pic is a input shaft. Look at oil feed hole where I got in mark in red. I have 4 input shafts here.This is the only one with that hole.And this is the shaft I had in the car. I want to use one of the other shafts..But I not sure what this feed hole is. Anyone know ?
The input shaft with the bushing lube hole is pre-'74, in '74 they changed the lube circuit so that the bushing is lubed by the output shaft; at the same time they eliminated the front clutch lube hole in the support, big mistake IMHO.
The INTERNET, the MISinformation superhighway
