Re: 727 fluid- What to use?
[Re: CompSyn]
#629451
03/03/10 08:58 PM
03/03/10 08:58 PM
Posts: 30,469 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Just know there could be possible drawbacks to using Ford Type F in your Chrysler transmission.
Frank Adkins explains in his book, Chrysler Performance Upgrades, that although Type F will cause a Chrysler 727 to shift better, the life span of of the front clutch pack can be dramatically reduced.
Then again in Carl Munroe's book, Torqueflite A-727 Transmission Handbook, "the type of transmission fluid used seems to have a definite effect on clutch life".
Sounds like if you have an all out race car and are not concerned about frequent transmission rebuilds, Type F is the way to go. Otherwise, a good Dexron fluid for a street/strip/show car would be a better choice.
Hey C S ....
Please define FREQUENT REBUILDS ?
In my 62 .... is a trans that I built back in the middle 70's ... it has had maybe 5 diff motors in front of it and maybe has 40k miles on it. The SAME type F fluid in it since day one.
Manual VB, trick drum, cut-down hemi band .... NO trash in the pan EVER.
Do you BELIEVE everything that you read ?
